Correction into integra
ljadx160
Posted 2/22/2025 15:46 (#11117703 - in reply to #11117649)
Subject: RE: Correction into integra
North Central Iowa
I tried to do some digging on Ag Leader's knowledgebase, but came up empty on any specific information on when NTRIP might have been added. Otherwise, I've just looked through the Integra manual where it's clearly covered, which appears to be current as of firmware version 7.2 while firmware 7.8 is the latest. What isn't detailed is how/whether the USB Wifi adapter would allow the built-in NTRIP client to pull the correction data from a Wifi hotspot (not just for Agfiniti), the pictures in the manual clearly show the use of dedicated modem instead. I would be a little surprised, however, if it didn't work. I would think a call to an Ag Leader dealer would firm this question up.
I don't have an Integra, so just going off what I can find on-line. I have Incommands and never used any older Ag Leader equipment (unless you count a YM2000 in my previous combine). I previously ran much older Trimble systems for steering.
